While using the integrated bus power supply, the UL 924-listed emergency contact input makes integration into emergency lighting systems easy for wet or dry connections.
The DALI Gateway MK2 uses a web interface connection as the primary method for configuring the device and all other connected DALI devices, streamlining the integration process during commissioning. This provides a technician with the ability
to move throughout the space and set levels and behaviors of individual fixtures as necessary.
Allowing a clean conversion workflow that aligns naturally with ETC’s broader control ecosystem and enables seamless operation alongside Paradigm, Mosaic, Echo, and other ETC entertainment systems.
