Cue List Indicator
The live and next cues are indicated on the main cue list and also in the cue list indicator in the upper right corner of the touchscreen.
The live cue displays in yellow and the next cue is in red. If a crossfade is underway, both will display in red.
Progress bars indicate the in and out fade position. When a follow time is running, a green status bar will display.
Note: When a crossfade is paused mid-way, it may be manually resumed by using the crossfader. The remaining progress will be shown in the cue list indicator.
Tap the cue list indicator to open the cue transport controls. The Cue Transport buttons are Back, Pause, and GO. These buttons may be assigned to the hard buttons below the screen, and are also always available by pressing on the cue list indicator in the upper right corner. Touch again to close the controls.
