Import Media
Importing Audio and Image clips.
All media used in a show must be stored locally inside the console.
Media may be imported from an external memory stick.
Only one copy of each media file is needed even if it is used in several shows. However, when a show is exported to a memory stick, all the included media is also included in the export.
Supported file types
- Audio: mp3, aac and wav files (44.1kHz sample rate, 4GB maximum file size)
- Image: jpg, png, tiff, and bmp files (1280 x 720 max size)
Note: It is recommended not to use the same name for different items of media. If the media is exported and then re-imported to the same console or another console, this would cause a local copy to be over-written.
Functions
- Import USB: imports media. The files must be in folder named Import or DCIM on a FAT32 formatted USB drive.
- Import Show: imports media from another show file.
- Delete Media: deletes selected media from your console.
CAUTION: All data is stored internally in non-volatile memory. Do not switch off the power until any pending save operation is completed, or you may lose data. It is strongly advised that you make periodic backups of important data to an external memory stick using the export function.
