Remove Default Show
The Default show is removed to a complete blank state with no patch or content at all.
Selecting File > New will start your device with no programmed content at all.
CAUTION: All data is stored internally in non-volatile memory. Do not switch off the power until any pending save operation is completed, or you may lose data. It is strongly advised that you make periodic backups of important data to an external memory stick using the export function.
