Solo Change
Note: The button modes; Flash, Solo, Solo Change, and Move/GO are only available when the faders mode is set to playbacks.
When the button mode is set to Solo Change, pressing the bump button for a playback will cause the channels in that playback to flash on depending on the intensity of each channel in the chosen playback.
If the chosen playback's channel is at an intensity above zero all the output from other playbacks or the cue list, for that channel, will be overridden. The intensity will be set to the level of the bumps master, and the color of the selected playback will be sent to the output, for that channel.
If the chosen playback's channel is at an intensity of zero, all the output from other playbacks or the cue list, for that channel, will be left unaffected.
Solo Change allows parts of the scene to be replaced while other parts are left unaffected.
