Filter, Position
Filtering is useful to play parts of a playback and leave other parts unaffected. Using this method you can play the pan/tilt part of one playback, the gobo and beam parts of a second playback, and the intensity and color mixing parts of a third playback to make a new composite playback.
The Position button toggles between position on and position off.
Switch off position to exclude it from playback when operating the blue GO buttons.
Note: If all parameters are off, the blue GO button will not do anything. However, the mauve intensity button can still launch the intensity and color mixing parts of the chosen playback.
