Hotkeys
The following is a list of common Eos functions and their associated Windows keyboard shortcuts.
Console FunctionWindows Keyboard Shortcut
Shortcut ListAlt /
00
11
22
33
44
55
66
77
88
99
. (decimal). (decimal)
- (minus)- (minus)
+ (plus)=
+%Shift =
 Control Alt =
-%Shift -
 Control Alt -
A3D Camera UpUp Arrow
A3D Camera Up (Edit Mode)W
A3D Camera ForwardsShift Up Arrow
A3D Camera Forwards (Edit Mode)Shift W
A3D Camera LeftLeft Arrow
A3D Camera Left (Edit Mode)A
A3D Camera DownDown Arrow
A3D Camera Down (Edit Mode)S
A3D Camera BackwardsShift Down Arrow
A3D Camera Backwards (Edit Mode)Shift S
A3D Camera RightRight Arrow
A3D Camera Right (Edit Mode)D
AboutY
Address / DimmerAlt A
All NPsControl N
AtA
Back (ECU)Escape
Beam FilterControl B
Beam PaletteAlt B
BlindF2
 Control 2
BlockB
CaptureControl Alt P
ClearBackspace
Clear Command LineShift Backspace
 Control Alt Backspace
Clear LabelControl Backspace
Color FilterControl C
Color PaletteAlt C
Color PathControl Alt W
Copy ToC
Cue
Q
Cue Only / TrackX
DataControl D
Data ModeControl Shift D
DelayD
DeleteDelete
Delete (macOS)Fn Delete
DisplaysF9
 Control 9
EffectAlt E
EnterEnter
EscapeEscape
ExpandF5
 Control 5
FlexiChannelF3
 Control 3
Focus FilterControl F
Focus PaletteAlt F
FollowShift D
 Control Alt D
FormatF4
 Control 4
(Scroller) FrameControl Alt C
FullF
GoSpacebar
Go To CueControl G
Go To Cue ZeroControl Alt G
GroupG
HelpAlt /
HomeHome
 Control H
Home (macOS)Fn Left Arrow
Intensity FilterControl I
Intensity PaletteAlt I
Label / NoteL
LastPage Up
 Control ,
Last (macOS)Fn Up Arrow
LearnAlt L
LevelControl V
LiveF1
 Control 1
LoadControl Alt L
MacroM
Macro 801*Control Alt 1
Macro 802*Control Alt 2
Macro 803*Control Alt 3
Macro 804*Control Alt 4
Macro 805*Control Alt 5
Macro 806*Control Alt 6
Macro 807*Control Alt 7
Macro 808*Control Alt 8
Macro 809*Control Alt 9
Macro 810*Control Alt 0
Magic SheetAlt M
Manual OverrideControl Alt M
 Control Alt N
Mirror StartAlt F1
Mirror StopAlt F2
ML ControlsF7
 Control 7
More Softkeys (More SK)Alt 7
NextPage Down
 Control
Next (macOS)Fn Down Arrow
OffControl Alt O
OffsetControl O
OutO
Page LeftLeft Arrow
Page RightRight Arrow
Page UpUp Arrow
Page DownDown Arrow
Parameters (Display)Control D
ParkAlt K
PartP
Patch;
RateControl Alt R
Recall FromE
RecordR
RecordOnlyControl R
ReleaseControl Alt S
Rem DimH
Scroll LockControl 6
SelectControl Enter
Select (ECU)Return
Select ActiveControl A
Select LastControl L
Select ManualControl M
SetupAlt S
ShiftZ
SnapshotControl S
SneakN
Softkey 1Alt 1
Softkey 2Alt 2
Softkey 3Alt 3
Softkey 4Alt 4
Softkey 5Alt 5
Softkey 6Alt 6
Spacebar DisableAlt G
Staging ModeF6
Stop / BackControl Spacebar
 Control Alt Q
Stop EffectShift Alt E
SubmasterS
TabTab
TimeI
Time (Displays)Control Alt I
Timing DisableControl Alt T
Toggle HotkeysF8
 Control 8
ThruT
UndoControl X
UpdateU
Virtual KeyboardControl K
Workspace] or [
Zoom selected displayLeft Mouse Button + Scroll Wheel
*Some Shortcut Key combinations are not available on all physical keyboard layouts.
^Alternatively use Encoder Display + category to change the encoder pages.
Note:  To enable Eos functions on macOS Function keys:
  1. Navigate to System Preferences > Keyboard
  2. Enable the “Use all F1, F2,etc... keys as standard function keys” setting.
Note:  Some international keyboards require “Use Shift Key As Eos Shift” to be disabled in Setup > Device > Face Panel > Input Devices. Use Z as shift to access shortcut functions in these cases.
