Keyboard Shortcuts
A list of common Eos functions and their associated QWERTY keyboard shortcuts.
Note:  Scroll Lock must be off to use keyboard shortcuts.
Console Function Windows Shortcut
Shortcut List Alt /
0 0
1 1
2 2
3 3
4 4
5 5
6 6
7 7
8 8
9 9
. (decimal) . (decimal)
- (minus) - (minus)
+ (plus) =
+% Shift =
Control Alt =
-% Shift -
Control Alt -
A3D Camera Up Up Arrow
A3D Camera Up (Edit Mode) W
A3D Camera Forwards Shift Up Arrow
A3D Camera Forwards (Edit Mode) Shift W
A3D Camera Left Left Arrow
A3D Camera Left (Edit Mode) A
A3D Camera Down Down Arrow
A3D Camera Down (Edit Mode) S
A3D Camera Backwards Shift Down Arrow
A3D Camera Backwards (Edit Mode) Shift S
A3D Camera Right Right Arrow
A3D Camera Right (Edit Mode) D
About Y
Address / Dimmer Alt A
All NPs Control N
Assert † Control W
Assert (Playback) † Control Alt A
At A
Back (ECU) Escape
Beam Filter Control B
Beam Palette Alt B
Blind F2
Control 2
Block B
Capture Control Alt P
Clear Backspace
Clear Command Line Shift Backspace
Control Alt Backspace
Clear Label Control Backspace
Color Filter Control C
Color Palette Alt C
Color Path Control Alt W
Copy To C
Cue Q
Cue Only / Track X
Data Control D
Data Mode Control Shift D
Delay D
Delete Delete
Delete (macOS) Fn Delete
Displays F9
Control 9
Effect Alt E
Effects Softkeys † Alt Shift E
Encoder Display (Gio) † Control Alt \
Encoder Page Color ^† Control Alt [
Encode Pager Focus ^† Control Alt ,
Encoder Page Form ^† Control Alt ;
Encoder Page Image ^† Control Alt ]
Encoder Page Intensity ^† Alt .
Encoder Page Shutter ^† Alt ,
Enter Enter
Escape Escape
Expand F5
Control 5
Fader Page † V
Fan † W
FlexiChannel F3
Control 3
Focus Filter Control F
Focus Palette Alt F
Follow / Hang † Shift D
Control Alt D
Format F4
Control 4
(Scroller) Frame Control Alt C
Freeze † Control Alt F
Full F
Go Spacebar
Go To Cue Control G
Go To Cue Zero Control Alt G
Group G
Help Alt /
Highlight † \
Control Alt H
Home Home
Control H
Home (macOS) Fn Left Arrow
Intensity Block † Shift B
Control Alt B
Intensity Filter Control I
Intensity Palette Alt I
Label / Note L
Last Page Up
Control ,
Last (macOS) Fn Up Arrow
Learn Alt L
Level Control V
Live F1
Control 1
Load Control Alt L
Macro M
Macro 801* Control Alt 1
Macro 802* Control Alt 2
Macro 803* Control Alt 3
Macro 804* Control Alt 4
Macro 805* Control Alt 5
Macro 806* Control Alt 6
Macro 807* Control Alt 7
Macro 808* Control Alt 8
Macro 809* Control Alt 9
Macro 810* Control Alt 0
Magic Sheet Alt M
Manual Override Control Alt M
Control Alt N
Mark † K
Control Alt K
Mirror Start Alt F1
Mirror Stop Alt F2
ML Controls F7
Control 7
More Softkeys (More SK) Alt 7
Next Page Down
Control
Next (macOS) Fn Down Arrow
Off Control Alt O
Offset Control O
Out O
Page Left Left Arrow
Page Right Right Arrow
Page Up Up Arrow
Page Down Down Arrow
Parameters (Display) Control D
Park Alt K
Part P
Patch ;
Pixel Map † Alt X
Preset † Alt P
Query † Control Q
Rate Control Alt R
Recall From E
Record R
RecordOnly Control R
Release Control Alt S
Rem Dim H
Scroll Lock Control 6
Select Control Enter
Select (ECU) Return
Select Active Control A
Select Last Control L
Select Manual Control M
Setup Alt S
Shift Z
Snapshot Control S
Sneak N
Softkey 1 Alt 1
Softkey 2 Alt 2
Softkey 3 Alt 3
Softkey 4 Alt 4
Softkey 5 Alt 5
Softkey 6 Alt 6
Spacebar Disable Alt G
Staging Mode F6
Stop / Back Control Spacebar
Control Alt Q
Stop Effect Shift Alt E
Submaster S
Tab Tab
Time I
Time (Displays) Control Alt I
Timing Disable Control Alt T
Toggle Hotkeys F8
Control 8
Trace † J
Thru T
Undo Control X
Update U
Virtual Keyboard Control K
Workspace ] or [
Zoom selected display Left Mouse Button + Scroll Wheel
* Some key combinations are not available on all physical keyboard layouts
^ Alternatively use Encoder Display + category to change the encoder pages
† Commands are not available on Element Classic
Note:  To enable Eos functions on macOS Function keys:
  1. Navigate to System Preferences > Keyboard
  2. Enable the “Use all F1, F2,etc... keys as standard function keys” setting.
Note:  Some international keyboards require “Use Shift Key As Eos Shift” to be disabled in Setup > Device > Face Panel > Input Devices. Use Z as shift to access shortcut functions in these cases.
