Once a macro is created, you can edit the content by removing or adding commands from the macro editor display.
Select an existing macro number and press [Enter]. The selected macro's contents will display in detail. Press {Edit} to make changes to the content.
The cursor in the macro content detail section of the display can be moved through the existing content list using the arrow keys. Arrow keys are not stored as macro content. To add content, place the cursor in the section that you want to insert, then add the command. To delete a command, place the cursor ahead of the content to be deleted, then press the {Delete} softkey.
Press [Select] when you have completed all editing. Press [Escape] to exit the editor.
Note: Macros for options with a toggle action between enable and disable, such as AutoMark in setup, can use the {Enable} and {Disable} softkeys for creating absolute actions instead of toggles.
In edit mode, the CIA displays all softkeys available for the system that would otherwise be difficult to find when recording a macro.
A new set of macro editor softkeys are displayed while in edit mode including:
Macros can also be created in the macro editor display. Enter any unrecorded macro number from 1 to 99,999 and press [Enter]. Your new macro number will display in the macro list in numerical order but without a label or any contents. To store the macro contents, select the macro and press {Edit}.
Example:
Creates macro 3. Writes the instruction to set all active channels to 50%, then sneak them to their original levels over 10 seconds and last, links to macro 5.
