Add an Existing Project
Add an existing project (in .pcf file format) to the server project by simply selecting the "Existing Project" checkbox then clicking the [Browse] button.
The "Open Project" dialog displays. Select the project file (*.pcf) and click [Open].
CAUTION:  It is possible to overwrite existing sub-project data with the new imported data. If a sub-project with the same filename already exists in the server project, the new sub-project data will replace / overwrite the pre-existing data. This is true with the exception of data that is explicitly related as part of the sub-project; such as a global preset or timed event that is associated across multiple sub-projects.
Click [Finish Project] to continue. The "Project List" for the server project displays.
