New Server Project Properties
New Server Project Properties is important system level related information such as the job name (consider the system-wide project name), job number, revision number, address and site contact information.
The LightDesigner server project file name is based on the job name (required), job number and revision specified in these properties.
Choosing the nearest city from the drop down box will assist LightDesigner's integration of the Astronomical Timeclock settings for the server project configuration. If manual coordinates is selected, you will be required to provide specific coordinates in the Property Editor once you begin configuration for the project.
Tip:  Changing the revision number as the LightDesigner project is modified will provide a "Save As" dialog, allowing for easy creation of multiple revisions of the same configuration.
Click the [Next] button to add sub-projects to the server project.
