Project Properties
Selecting the project name (or server project name) from the top of the Browser list, displays the entire project (or all projects in the server project) including all spaces in the Plan workspace, and displays the project properties in the Property Editor.
Server Project Properties
Project Properties inside Server Project
Individual Project Properties
Tip: Unless specified otherwise below, the properties in the editor are assumed to be selectable and enabled for editing. Properties that are enabled for an Advanced user only are indicated in blue if the user color for advanced level access items setting is enabled. All known properties for all project types are listed below.
Note: If you have a configured time server or if your Paradigm Processor is part of a server system, you cannot set or edit time related settings from the facepanel of the Paradigm Processor. Changes to timezone and DST must be made in LightDesigner. If the project is a server project, matching changes to the Net3 Conductor configuration must be made in the Net3 Conductor web interface. See System Time for more information.
