Using [Format]
Live / Blind has multiple formats. When first opened, it opens in its default view, which is the Table View. The default view can be set in the Live and Blind Configuration Menu . When the default format has been changed, those new settings will be used whenever the display is changed back to that format.
Press [Format] to rotate through any available formats.
Live and Blind share formatting. When you change from one format to another format, you are always working with the same format until you change it. The exception to this is Spreadsheet (Blind Only), which is only available in blind. If you are working in blind spreadsheet, when you return to live you will be working with the table or summary view, based on which one you were last using.
