The editor is used to create new or edit copied scrolls and wheels. While in the picker display, you can create a new scroll or wheel by pressing the {New} softkey or make a copy of an existing scroll or wheel by selecting the source, then pressing the {Copy} softkey.
The editor does not limit how many frames you can add to the scroll or wheel for the selected fixtures. Keep in mind that any fixture has its own limitations. For example, if you have created a custom color scroll with 30 frames, your selected fixture type may only provide you access to the first 24 frames that you created. This applies to wheels as well.
Note: If you try to select an existing scroll or wheel, the console will display a warning if it has more frames than are supported by your device.
When using the editor, the following softkeys are available for use:
