Snap Parameters
Certain parameters may not want to be subjected to cue timing. Those parameters can be set to snap. By default, Eos will snap the parameters listed in the following table:
Beam FX Index/Speed Effect Library MSpeed Shutter
Camera IR Image Enable Negative Shutter Strobe
Clip Directory File Object Directory Strobe Mechanism
Color Effect File Type Object File Sync Source
Color Index Front/Rear Projection Output Command Text
Color Mix Generator Page Texture
Control Generic Control Position Blink Timeline
Copy Mod Image Movement Speed Projector Input Timeline Position
Cue Internal Media Frame Relay Tracking Object
Dimmer Curve Library Select Transition Speed
Edge Blend Profile Macro Shape Transition Time
Effect File Mode Shape Library Transition Type
In the [About] channel patch screen, the snap column shows which parameters for that channel are currently set to snap. These parameters can be edited for any profile using the Fixture Editor. See Fixture Editor
