Note: This option is not available on Element 2 and Element Classic.
Enables or disables AutoMark. Disabled by default. See AutoMark.
This field allows you to set the time that mark instructions will use, and is disabled by default. When disabled, mark instructions will use cue timing unless overridden with discrete timing.
When you enter a mark time in setup, all NPs that mark (either via referenced marking or AutoMark) will use this time. The only way to override the mark time in Setup is to use discrete timing.
Select {Mark Time}[Enter] to clear the field and disable the default mark time.
See Mark (on page 1).
If this option is disabled, the cue’s up intensity time will be used when preheating. The default setting is “Disabled”.
This area allows you to set the default cue times for the parameter categories of your system. To change a time, touch the parameter category button in the CIA and enter the desired time on the keypad. To set a time for all categories at once, select the first category and press [Thru]. Pressing [At] selects manual times.
The categories for which you may set default times are:
