This section allows you to define how much a parameter changes when an encoder is rotated one full revolution.
Note: Hold down [Shift] while moving the encoder for fine control. Releasing the [Shift] key will restore the encoder to its default mode.
How much any associated parameters (excluding pan and tilt) change in one full revolution of an encoder. Measured in a percentage of the parameter's entire range. Defaults to 35.
How much the pan and tilt parameters change in one full revolution of an encoder. Measured in degrees. Defaults to 30.
Note: This option is only applicable to Eos Apex consoles.
How much any associated parameters change in one full revolution of a mini encoder. Defaults to 35.
How much any associated parameters change in one full revolution of an endless fader wheel. Defaults to 125.
This section allows you to specify the values for certain buttons or settings used in manual control. The following settings are available:
This section allows you to specify highlight preferences. The following settings are available:
This section allows you to specify a custom encoder mapping to be used as the default for all
fixtures. If left blank, any fixture types without a custom map assigned will use the default Eos encoder mapping.
For more information on custom encoder maps, see Custom Encoder Maps.
