User > Displays
{Preserve Blind Cue}
This enables the console to display the last selected cue in blind when you return to blind. Disabled by default.
{Blind Next/Last Affects Target}
When enabled, in Blind the Next and Last commands will always apply to channels, if a channel selection is on the command line. Disabled by default.
Popup Magic Sheet
Assigns a magic sheet (see About Magic Sheets) that can be accessed via the Quick Access tools.
{Popup Nav Lock}
Enables or disables the zoom and scroll navigation for your {Popup Magic Sheet}. Enabled by default.
{Augment3d Display Behavior}
The following Augment3d display behaviors are available:
- Normal Display - the display will behave the same as a display tab.
- A locked tab will not be skipped.
- A single click on the tab will draw focus to that tab.
- Channel Display - this mode uses the following rules:
- When focus is drawn to the playback status display, an Augment3d channel display will be brought to the front.
- [Shift] & [Live] will cycle through Augment3d channel displays alongside Live channel displays.
- Pressing [Live] or bringing a Live tab into focus will restore your last focused Augment3d channel display.
- Augment3d channel displays in the locked frame will not be skipped when using the [Tab] key to cycle through tabs.
- Control - the display will behave the same as a controls tab.
- Locked tabs will be skipped.
- A single click will not draw focus.
- A double click will draw focus to the tab.
{Display Fader Ribbon}
Element Classic only. Enables or disables the ribbon display showing the status of the
faders. When disabled, the fader ribbon will not display. Enabled by
default.
