Trackball settings to swap the pan and tilt parameters. Defaults to disabled.
Reverses the range of the pan parameter. Defaults to disabled.
Reverses the range of the tilt parameter. Defaults to disabled.
Allows you to enable the spacebar on an external keyboard as the hotkey for [Go]. Defaults to enabled.
Allows the SHIFT key on an alphanumeric keyboard to be used as the console's [Shift] key. The Z key on an alphanumeric keyboard will function as the [Shift] key. Defaults to enabled.
With hide mouse enabled, if the mouse is left idle for 10 seconds, the cursor will go away. Once the mouse is used again, the cursor will return. Defaults to disabled.
Sets the delay for keystroke input from an external device.
Sets the keystroke speed from an external device.
Disabled by default. When enabled, allows you to adjust the volume level of the following system alert sounds:
All sounds default to 0.
Note: This option is only applicable to Eos Apex consoles.
Allows you to enable or disable haptic feedback.
