Recording Snapshots
Note:  On Element 2 and Element Classic consoles, {Snapshot} is a softkey.
To store the current state of the console, record a snapshot.
When recording a snapshot, you will see a preview of all of the displays as they will be recorded in the snapshot. You can choose to select/ deselect various components, monitors, frames, etc from your snapshot.
From the snapshot menu, the following options are available:
Note:  The Faders and Encoders options are not available on Element 2.
You may also check or uncheck to include or exclude any of the following:
When one or more sublevel items are excluded, a minus (-) icon will appear next to the top level item to indicate that not every available option will be saved. A checkmark icon will display when every sublevel item will be saved.
Monitors and frames can also be selected or deselected in the preview area. Use {Frames/Monitors} in the top right to toggle between monitor or frame numbers. Deselected monitors and frames will be greyed out. Deselected frames will also display a slashed red circle icon.
