Note: This option is not available on Element 2 or Element Classic.
This toggles the AutoMark settings between enabled/ disabled (see AutoMark for more information). AutoMark is “Disabled” by default.
This field allows you to set the time that mark instructions will use. When mark time is disabled, which is the default, mark instructions will use cue timing unless overridden with discrete timing.
When you enter a mark time in setup, all NPs that mark (either through referenced marking or AutoMark) will use this time. The only way to override setup mark time is to use discrete timing. Clearing the mark time field sets it back to disabled. Select Mark Time and hit [Enter] to disable the default mark time.
If this option is disabled, the cue’s up intensity time will be used when preheating. The default setting is “Disabled”.
This area allows you to set the default cue times for the parameter categories of your system. To change a time, touch the parameter category button in the CIA and enter the desired time on the keypad. To set a time for all categories at once, select the first category and press [Thru]. Pressing [At] selects manual times.
The categories for which you may set default times are:
