About the Eos Configuration Utility
This section covers the Eos Configuration Utility (ECU) and its uses for both system configuration and performing basic level test functions.
You can force the console to boot into the utility instead of the main console application. During the boot process, a countdown timer will appear. You will have 5 seconds to click the timer or to hold down “e”, “o” and “s” at the same time on a connected alphanumeric keyboard. Otherwise, you can enter the ECU from the Eos application by choosing Browser > Exit.
Consoles can also be assigned to always boot directly into the ECU. See Open in "Shell" E.C.U..
