ETC moves into the stage manager’s desk with CueSystem
Date Posted: 9/13/2016
As part of an ongoing partnership with the UK-based GDS, ETC is now shipping
CueSystem
, a dedicated cue light network that scales effortlessly for any show or venue. CueSystem is backstage communication done right, providing hands-on cue light control and advanced, pre-programmed playback options. With American manufacture, distribution and support now handled by ETC, CueSystem is poised to help venues across the region keep their shows on track.
The new standard in cue lights
With CueSystem, you don't have to trust the crucial moments of your production to a homemade cue light circuit or to chance. The network-based system of controllers and outstations facilitates safe, bi-directional communication; pressing a blinking "standby" button on a
CueSpider outstation
alerts the stage manager that the operator is in place and ready for the "go" command.
Setup and customization of CueSystem is easy. Components connect using a standard Ethernet switch, creating a flexible and scalable cue light system that can work with your venue's existing network hardware. CueSpider outstations require only a power-over-Ethernet cable run, and they can be daisy-chained together for larger shows. The other CueSystem hardware and software offerings can be mixed and matched to provide the perfect playback and control setup for any size production. With the free, downloadable PC application, patching is a point-and-click process.
Hands-on control
The simplest CueSystem network consists of a control
Desk
and a series of outstations. Desks come in three sizes, with buttons that directly control the "standby" and "go" lights on four, eight or twelve cue light channels. CueSystem Desks are available in desktop or rack-mount configurations to make the most of a crowded stage manager's station, and multiple Desks can be added to the network as production needs increase.
Cue lists for your cue lights
Working on a long-running or complex show with multiple cues firing at once? The
CueSystem software
lets you create pre-programmed cue stacks. Simply select the "standby" and "go" lights to be triggered, add a descriptive name to the cue, and record it to the stack. Information about current and upcoming cues is displayed on each CueSpider readout display, allowing backstage operators or onstage presenters to keep on track without the use of headsets. Advance your cue list from the PC with a click or a keystroke, or opt for the security of a dedicated
Playback Unit
. Either way, you can standby for a smooth show.
