OneTrack by ETC Expands with 277 V Compatibility
Date Posted: 3/27/2024
ETC, a global leader in lighting solutions, announces the expansion of OneTrack by ETC with the addition of 277 V surface/suspension mount track plus 120 V and 277 V recessed mount track. Alongside this
release, ETC announces OneTrack 277 V models of Irideon
FPZ and Irideon
WLZ luminaires. Together, OneTrack by ETC and Irideon offer reliable and flexible track lighting solutions for a wide range of installations.
With the addition of 277 V and recessed mount options, OneTrack fits seamlessly into even more buildings, saving money on line voltage wiring and allowing more fixtures to fit on a circuit. Surface mount 277 V track is available in black or white, comes
in standard lengths of 4, 8, and 12 feet (1, 2, and 4 meters), and can be used with the same suspension mount brackets and accessories as 120 V OneTrack. The new 277 V version of OneTrack is also compatible with OneTrack Backbone by ETC, which adds
a strong H-shaped aluminum extrusion to reinforce the track. Backbone allows OneTrack to be used with full-sized theatrical fixtures using a hanging clamp with power and data plug-in adapters.
Recessed mount track is available in black or white and comes in standard lengths of 4 and 8 feet (1 and 2 meters). Recessed mount track uses the same feeds and couplers as surface mount track, plus additional covers that must be ordered separately. OneTrack
is designed so that 120 V luminaires cannot be accidentally installed on 277 V track systems, and vice versa.
“Lighting designers and specifiers will have even more track lighting options at their fingertips with the addition of 277 V OneTrack by ETC,” said Ned Keitt, Product Manager at ETC. “Whether using ETC’s Irideon fixtures or third-party fixtures, customers
can flexibly design an entire system that fits their needs.”
OneTrack 277 V is available for sale in North America for 277 V applications. It is also available for sale in Latin America, the Middle East, and Asia for 240 V applications, or any other location that uses 240 V and does not require CE compliance.
