  • Cruise Ship Lighting Systems
    Your entire vessel, one sophisticated lighting system
    ETC’s philosophy for cruise ship environments is ‘think globally, act locally.’ Having a ship-wide ETC lighting system makes programming and commission time quick and easy. Using lighting, controls, and dimming from a single manufacturer guarantees long-term compatibility when software upgrades or changes are needed. From the central command center, to each room’s wall stations, to the beautiful beams lighting cabins, common areas, and more, ETC has the solutions you need. And all of our solutions are backed by our legendary 24/7 tech support team.
    *Click on any product in the image for more information about that product
  • Intuitive & Far-Reaching Architectural Control
    Paradigm 410-Remote App
    Unison Paradigm
    Easy-to-navigate, ship-wide lighting controls for cruise vessels of any size. Monitor and control every aspect of your lighting system with the wide array of Unison Paradigm solutions.
    • Control from touchscreens, elegant wall stations, and apps
    • Occupancy sensing, daylight harvesting, and time-scheduling capabilities
    • Energy monitoring options
    Mosaic TPC Front Image
    Unison Mosaic
    Merge lighting control, show control, and media effects on your ship with Mosaic’s advanced tools. From interior light shows to artful displays on ship exteriors, Mosaic meets your complex design needs.
    • Sophisticated software that streamlines the design process
    • Durable hardware solutions for installations of any size
    • Layered, dynamic control with pixel mapping and timeline programming
    Echo Room Controller
    Unison Echo
    Create a distributed control system on your vessel with intelligent Echo solutions. Whether you need basic control, presets, daylighting and occupancy controls, or color control of LED luminaires, Echo has a solution.
    • Independent control of rooms
    • Daylight and occupancy controls
    • Compatibility with color-changing LED luminaires
    Accessible LED Power Control
    F-Drive Card
    F-Drive
    Service LED systems on your vessel from a central location with the modular F-Drive LED power control solution.
    • Simple access to driver cards and power supplies
    • 48 VDC Input (via separate power supply)
    • RJ45 output connectors (CC Cards only)
    • Phoenix modular output connectors for high gauge wire
    • DMX/RDM control input
    • Enhanced third-party LED fixture compatibility via B-Box accessory
    F-Drive
    Elegant & Flexible Architectural Luminaires
    ArcSystem Pro
    ArcSystem Pro
    ArcSystem Pro is a family of LED products designed for easy installation, high-quality light, and smooth dimming. With the retrofit ArcLamp solution as well as multiple form factors in One-Cell and Multi-Cell luminaires, cruise ships can select from a wide array of solutions.
    • Wired-DMX or wireless (ArcMesh) control protocols
    • Stepless smooth dimming to blackout
    • Convection cooled
    • Fan-free, silent operation
    • Multiple color-temperature and fixture color options
    Irideon
    Irideon
    The Irideon line features exceptional light output and a sleek, industrial look. The feature-rich design of both the FPZ (Framing Projector Zoom) fixture and the WLZ (Wash Light Zoom) fixture is ideal for many spaces on your vessel.
    • DMX control with built-in intensity trim feature
    • DALI or 0–10 V control option available for canopy version
    • Dimming to less than 1% of maximum output
    • Available in black, white, silver, and custom paint colors
    Industry-leading Entertainment Controls
    Eos consoles
    Eos consoles
    In entertainment spaces onboard, lighting programmers can take full advantage of the award-winning Eos features such as sophisticated 3D-programming and color tools.
    • Award-winning color controls, including Gel & Color Pickers for LED and CMY color mixing
    • Revolutionary Augment3d 3D programming environment
    • User configurable, interactive Magic Sheets
    • Distributed DMX, MIDI, SMPTE, and contact closure via Net3 and Response Gateways
    Eos consoles
    Bold & Bright Entertainment Luminaires
    Source Four LED Series 3
    Source Four LED
    Source Four LED solutions revolutionized what’s possible in LED lighting. With optimized arrays and finely tuned electronics, all Source Four LED options offer a combination of light quality and output for beautiful lighting on any vessel.
    • Lustr x7 and x8 color-mixing systems for exceptional color
    • Lustr fixtures hold a 54,000-hour L70 Rating
    • Slots for glass or stainless steel patterns and soft focus diffuser
    • Accessory slot for motorized pattern devices or optional iris
    • DMX512 in/thru via five-pin XLR connectors
    ColorSource
    ColorSource
    ColorSource fixtures offer incredible output, stunning colors, and perfect dimming at an affordable price. ColorSource is an exceptional choice when a ship’s lighting budget is modest.
    • Spot, Spot jr, PAR, Linear, and CYC options
    • ETC’s RGB-L array (red, green, blue, and lime)
    • Also available in Deep Blue, which replaces the blue LEDs with indigo for rich, saturated blues and magentas
    • Simple user interface with seven-segment display
    • powerCON® in and thru
    High End Systems
    High End Systems
    For more than 30 years, High End Systems automated lighting has been at the forefront of live production worldwide. With a wide range of lighting solutions, these fixtures are ready to meet any vessel’s moving light needs. Look forward to these features and more in much of the High End Systems range:
    • Frame, Spot, Wash, Hybrid, and Effects options
    • CMY color mixing
    • An Ultra-Bright engine for maximum lumens or a High CRI / High Fidelity engine for superior color rendering
    • Patented Lens Defogger
    • Extended LED life with 5 year engine warranty
    Download Cruise Ship Brochure
    Interested in learning more about cruise ship solutions?
    Cruise Ship Interior
    Cruise Ship Lounge
