sACN port universe format can be entered in any of the following ways:
Universe - An example of this format can be 1. This example means that Port 1 Universe is assigned to sACN Universe 1 and listens or outputs on all 512 addresses of sACN universe 1.
Universe/Address - An example of this format can be 2/50. This example means that Port 1 Universe is assigned to sACN Universe 2 and listens or outputs on only address 50 of sACN universe 2.
Universe/Address:Length - An example of this format can be 101/1:250. This example means that Port 1 Universe is assigned to sACN universe 101, and listens or outputs only on DMX addresses 1 through 250.
Universe:Length - An example of this format can be 2:150. This example means that Port 1 Universe is assigned to sACN universe 2 and listens or outputs on only the first 150 DMX addresses.
/Address - This is an EDMX-like value where the universe and address is calculated. An example of this format can be /1025. This example means that Port 1 Universe is assigned to sACN universe 3 address 1 and listens or outputs on only DMX address 1.
/Address:Length - This is an EDMX-like value where universe is calculated. An example of this format can be /1025:50. This example means that Port 1 Universe is assigned to sACN universe 3 and listens or outputs only on DMX addresses 1 through 50.
Use the following format to specify a Dimmer Doubling address:
