Configuring I/O Gateways
Right-click on a gateway from either the "Online Devices" table or the "Device Configurations" table and select "Edit Device Configuration" from the context menu or select a gateway and choose "Edit Device Configuration" from the (Edit) menu or double-click the "Status" cell of the device row to be edited.
If the selected device is from the "Online Devices" table, the dialog contains five tabs for edit including "Identity", "Analog", "Relay", "Serial" and "About". If the selected device is from the "Device Configurations" table, the dialog contains only the first four tabs. Each tab is provided for setting the write-able properties and displaying the read-only properties of a Net3 I/O Gateway.
  • When this dialog is opened from within the "Device Configurations" table, selecting the [OK] button saves changes to the configuration record only and does not make any changes to any online device.
  • When the dialog is opened from the "Online Devices" table, selecting the [OK] button sends changes to the online device only and does not affect any bound entries in the "Device Configurations" table.
  • Selecting the [Cancel] button ignores any changes that were made and closes the dialog.
