Eos Update
  • ETC is committed to navigating the constantly-evolving challenges of the ongoing global parts shortages. This page contains the most up-to-date information on affected Eos products, as we roll out internal component revisions.
    Last Updated: 06/01/2023
    Eos v3.2.1 has been replaced by Eos v3.2.2
    Eos v3.2.2 has been released, which corrects a critical issue during a firmware upgrade that can result in the console losing its license (output count). This issue only exists for consoles built after July 2022, that have been upgraded to Eos v3.2.1. Users who have upgraded to v3.2.1 should move to v3.2.2 as soon as they are able, and users moving from v3.2.0 or earlier should move directly to v3.2.2 when they are upgrading.
    If your console is affected, DO NOT attempt to update firmware on the “Intelligent Power Board IMX RT” module in the shell - a failed update will result in the console needing to return to an ETC Service Provider to be restored to operational condition. If your console is not affected or you do not attempt to upgrade the Intelligent Power Board, Eos v3.2.1 is fully functional and stable, but ETC recommends moving to v3.2.2 when possible to remove the threat of issues.
    Affected Products: only products manufactured after July 2022 that use the “Intelligent Power Board IMX RT” circuit boards can be affected. These are used in Element 2, Ion Xe, Ion Xe 20, Ion Xe PRU, Gio @5, Apex Processor, and Eos Remote Interface (full Apex consoles, Programming Wings, Pucks, and legacy hardware are not affected). If you are unsure if your console is affected, grab the device’s serial number and check the list below.
    Eos v3.2.1 has been fully replaced by v3.2.2 on our website. If you have a specific need for Eos v3.2.1 software or if you have further questions, please contact Technical Support.
    As of 2022-08-22, the following consoles will ship with redesigned internal components and firmware v2.0.0 installed:
    • Element 2
    • Ion Xe
    • Ion Xe 20
    • Ion Xe RPU
    • Gio @5
    • Apex 5, 10, 20
    • Apex Processor
    • Eos Remote Interface
    • Eos Programming Wing
    As of 2022-10-17, the following products will ship with redesigned internal components and firmware v2.1.0 installed:
    • Gadget II
    Firmware v2.0.0 and v2.1.0 have a reduced set of features. Future firmware versions will be released to restore these features. We will keep this page up-to-date as new firmware becomes available. Please reference each console's information below for details:
    Affected Serial Numbers:
    • Element 2 1k - 434833114 and higher.
    • Element 2 6k - 434860517 and higher.
    Element 2 consoles shipped after 2022-08-22 will contain one or more of the following new modules which require the listed minimum firmware version:
     Module Name
     Minimum Firmware
      Face Panel HS IMX 2.0.0
      Element 2 Faders IMX 2.0.0
      Four Port I/O Board IMX HS 2.0.0
      Intelligent Power IMX 2.0.0
    To view the modules installed in your console, go to ECU Settings > Maintenance > Detected Modules.
    Firmware v2.0.0 does not support the following features:
    • Remote Device Management (RDM)
      (Workaround: use a networked ETC Net3 or Response DMX gateway)
    • Device firmware update via DMX ports
    • Local contact closures and relay output
      (Workaround: use a networked ETC Net3 or Response I/O gateway)
    • Dimming of face panel backlight and indicators
      (There is currently no workaround)
    • Live dimming of Littlite during brightness level adjustments.
      (Note: The brightness will not change while moving the fader, but will update a few seconds after releasing the mouse click. This affects both brightness settings in Eos, as well as the test app in the ECU (Shell))
    Note: If you need to install Eos v3.1.4 on consoles that contain older module hardware (for example - in order to network older and newer consoles), doing so will not remove any features from the older consoles, and firmware v2.0.0 will not be installed on the older modules.
    Element 2
    • Ion Xe 2k - 434112138 and higher
    • Ion Xe 12k – 434160517 and higher
    Ion Xe consoles shipped after 2022-08-22 will contain the following new modules which require the listed minimum firmware version:
     Module Name
     Minimum Firmware
      Eos Main Playback IMX 2.0.0
    Ion Xe
    • Ion Xe 20 2k - 434213739 and higher
    • Ion Xe 20 12k - 434261042 and higher
    Ion Xe 20 consoles shipped after 2022-08-22 will contain the following new modules which require the listed minimum firmware version:
     Module Name
     Minimum Firmware
      Ion Xe/Standard Faders IMX  2.0.0
    Ion Xe 20
    • Ion Xe RPU 2k – 434310517 and higher
    • Ion Xe RPU 12k – 434315514 and higher
    Ion Xe RPU consoles shipped after 2022-08-22 will contain the following new modules which require the listed minimum firmware version:
     Module Name
     Minimum Firmware
    Ion Xe RPU
    • 491420183 and higher
    Gio @5 consoles shipped after 2023-01-01 will contain the following new modules which require the listed minimum firmware version:
    Module Name
    Minimum Firmware
      Eos 6x2 IMX 2.0.0
      Eos Main Playback Motor IMX 2.0.0
    Gio @5
    • Apex 5: 443044033 and higher
    • Apex 10: 443040079 and higher
    • Apex 20: Serial number ranges will be updated when shipping resumes
    Apex 5, Apex 10, and Apex 20 consoles shipped after 2022-12-12 will contain the following new modules which require the listed minimum firmware version:
     Module Name
     Minimum Firmware
      Apex Intelligent Power IMX 2.0.0
      Apex Main Playback IMX 2.0.0
      Apex Haptic Encoder IMX 2.0.0
    • Apex Processor: 443064030 and higher
    • Eos Remote Interface: Serial number ranges will be updated when shipping resumes
    Apex Processor and Eos Remote Interfaces shipped after 2022-12-12 will contain the following new modules which require the listed minimum firmware version:
     Module Name
     Minimum Firmware
    Apex Processor Eos Remote Interface
    • Gadget II – 493430001 and higher
    Gadget II shipped after 2022-10-17 will contain the following new modules which require the listed minimum firmware version:
     Module Name
     Minimum Firmware
      Gadget II (CPU2 / IMX) 2.1.0
    To view the firmware in your Gadget II, attach is via USB to any Eos Family console or computer running Eos Software and go to ECU Settings > Maintenance > Detected Modules.
    Firmware v2.1.0 does not support the following features:
    • Configuration from Concert software
    • Compatibility with Hog consoles and software
    • Compatibility with Cobalt consoles and software
    • For use with Eos consoles and software, a minimum software version of 3.1.4 is required
    Gadget II
    • 492001361 and higher
    Eos Programming Wings shipped after 2023-01-12 will contain the following new modules which require the listed minimum firmware version:
     Module Name
     Minimum Firmware
    To view the modules installed in your programming wing, attach is via USB to any computer running Eos Software and go to ECU Settings > Maintenance > Detected Modules.
    Element 2
    Affected Serial Numbers: Element 2 1k - 434833114 and higher. Element 2 6k - 434860517 and higher.
    Element 2 consoles shipped after 2022-08-22 will contain the following new modules which require the listed minimum firmware version:
    Module: Face Panel HS IMX
    Min. Firmware: 2.0.0
    Module: Element 2 Faders IMX
    Module: Four Port I/O Board IMX HS
    Module: Intelligent Power IMX
    Element 2
    Ion Xe
    Affected Serial Numbers: Ion Xe 2k - 434112138 and higher, Ion Xe 12k – 434160517 and higher.
    Module: Eos Main Playback IMX
    Ion Xe
    Ion Xe 20
    Affected Serial Numbers: Ion Xe 20 2k - 434213739 and higher. Ion Xe 20 12k - 434261042 and higher.
    Module: Ion Xe/Standard Faders IMX
    Ion Xe 20
    Ion Xe RPU
    Affected Serial Numbers: Ion Xe RPU 2k – 434310517 and higher, Ion Xe RPU 12k – 434315514 and higher.
    Ion Xe RPU
    Gio @5
    Affected Serial Numbers: 491420183 and higher.
    Module:Eos 6x2 IMX
    Module:Eos Main Playback Motor IMX
    Gio @5
    Apex 5, 10, 20
    Affected Serial Numbers: Apex 5: 443044033 and higher, Apex 10: 443040079 and higher, Apex 20: Serial number ranges will be updated when shipping resumes.
    Module: Apex Intelligent Power IMX
    Module: Apex Main Playback IMX
    Module: Apex Haptic Encoder IMX
    Apex 5, 10, 20
    Apex Proc, Eos Rem. Int.
    Affected Serial Numbers: Apex Processor: 443064030 and higher, Eos Remote Interface: Serial number ranges will be updated when shipping resumes.
    Gadet II
    Affected Serial Numbers: Gadget II – 493430001 and higher.
    Module: Gadget II (CPU2 / IMX)
    Min. Firmware: 2.1.0
    To view the firmware in your Gadget II, attach it via USB to any Eos Family console or computer running Eos Software, and go to ECU Settings > Maintenance > Detected Modules
    Gadget II
    Programming Wing
    Affected Serial Numbers: 492001361 and higher.
    Module:Eos Main Playback IMX
    Module:Four Port I/O Board IMX HS
    Programming Wing
  • Explore the Eos Family
    Eos Home
    Explore Eos Family user resources at the Eos [Home]
    Eos Home image
