Time/ Rate
Playbacks may be given a fade time. When either a bump or Playback Toy Intensity button is pressed, the intensity and parameter parts will fade in at the rate set on the Time button, shown in gray.
If the playback contains a sequence, the gray button will indicate the rate.
Holding down the gray button will open a keypad to alter the time (for playbacks) or the Rate (for sequences).
