Face Panel Shortcuts
Overview
The following is a list of button pushes: single, maintained, or combined. It is highly recommended that you read and familiarize yourself with this list.
See also Keyboard Shortcuts .
Displays
- [Data] (maintained press) - toggles the display to show data living under referenced data. Keep [Data] depressed to page. [Data] & [Data] locks this display.
- [About] & [Data] - locks the display to the absolute data display.
- [Time] (maintained press) - toggles the display to show discrete timing. Keep [Time] depressed to page.
- [About] & [Time] - locks the display to discrete time display. Press [About] & [Time] [Time] to unlock, or temporarily display discrete time.
- [Data] & [Focus] / [Color] / [Beam] - to expand/ suppress categories on displays. (Ion)
- [Data] & {Parameter Tiles} - to suppress/ display individual parameters from the display when not in summary view. (Ion)
- [Params] & [Focus] / [Color] / [Beam] - to expand/ suppress categories on displays. (Ti/ Eos/ Gio)
- [Params] & {Parameter Tiles} - to suppress/ display individual parameters from the display when not in summary view. (Ti/ Eos/ Gio)
- [Displays] & [Level Wheel] - controls the Main slider in Brightness Settings.
- [Displays] [Displays] - resets the CIA to the browser.
- [About] & [Path]/{ Color Path} - toggles the display to show the color paths.
- [Shift] & [Select] - reset display columns.
- [Shift] & [Tab] - clear all tabs on the current monitor (but keep locked frames) (Does not clear tab 1 and 2).
- [Shift] & [Tab] [Tab] - clear all tabs on all monitors (but keep locked frames) (Does not clear tab 1 and 2).
- [Shift] & [Tab] [Tab] [Tab] - clear all tabs on all monitors (including locked frames) (does not clear tab 1 and 2).
- [Shift] & [Label] - opens the cue note for the selected cue. Adds a note to a currently selected cue if one doesn't already exist.
- [About] & [Label] [Label] - double press to lock reference labels on. Press [About] & [Label] again to unlock.
- [Shift] & [Live/ Blind] - advances the displays to the next instance of Live or Blind.
- [Live] (when already in Live) - resyncs the selected cue to the most recently activated cue.
- [Blind] (when already in Blind) - resyncs the selected cue to the live selected cue (when blind cue has been changed or when preserve blind cue has been enabled).
- [Flexi] & [Time] - to invoke flexi time view on displays.
- [Format] & [Level Wheel] - zooms the display in focus.
- [Tab] & [Up/Down Arrow] - cycle workspaces.
- [Tab] & [Left/Right Arrow] - move displays.
- [Tab] & [number] - open or focus specific displays.
- [Flexi] & [.] - turns on Flexi multicells off mode. Press again to turn off.
[About] & [Live] - displays the DMX values.
[About] & [Mark] - displays the mark cue used by the channels.
[About] & [Next]/[Last] - displays the next cue that the channels move in or the last cue that the channels moved in.
[About] & [Park] - displays the parked levels.
[About] & [Part] - displays the cue part number for each parameter.
- [Expand] & [Effect] - opens the Effect Status Display (Tab 8).
Face Panel
- [Shift] & [Escape] - to lock and unlock face panel.
- Encoder Paging Keys & [Number] - pages to the desired encoder control page.
- [Escape] & Encoder Paging Keys - locks the encoders. Press any encoder page button to unlock.
- [Flexi] & Encoder Paging Key - to invoke flexi encoder states.
- [Fader Controls] & [Bump Button] - select a fader page on wings.
- [Fader Page] & Rate Wheel - rolls the selected fader page. (Ti/Eos/Gio)
- [Fader Page] & [number] - select a fader page on integral faders. (Ti/Eos/Gio)
- [Fader Page] - increments the fader page by 1.(Ti/Eos/Gio)
- [Shift] & [Fader Page] - decrements the fader page by 1. (Ti/Eos/Gio)
[Learn] & [Load] - opens the selected fader's configuration tools.
- [Off] & [Load] - releases control of content, restoring to background and leave cue list with pending cue in tact.
- [Release] & [Load] - releases control of content, restoring to background, and resets cue list to top.
- [Shift] & [Go] or [Shift] & [Back] - cuts the pending cue or the previous cue.
- [Shift] & [Load] - to remove content from a fader.
- [Shift] & [Stage] - toggles Scroll Lock on and off.
Operations
- [At] [Enter] - removes move information from selected channel/parameters.
- [At] [At] - set to Level (as defined in Setup).
- [Color] (Encoder Paging Key) & Encoder Movement - hold Color Point while adjusting parameters.
- [Copy To] [Copy to] - posts Move To on the command line.
- [Full] [Full] - sets selected channels intensity to “full” and self terminates.
- [Label] [Label] - appended to a record target command, clears the current label, this includes show file labels.
- [Recall From] [Recall From] - posts Recall From Cue to the command line.
- [Record] [Record] - posts Record Only to the command line.
- [Select Active] [Select Active] - Select Active minus submaster contributions.
- [Shift] & [Select Active] - posts Select Non-Sub Active.
- [Shift] & [Enter] - repeats last command line, unterminated; does a loop of last five commands.
- [Shift] & [At] - recalls last channel(s) and parameters without terminating; does a loop of last five commands.
- [Shift] & [Block] - posts Intensity Block to the command line.
- [Shift] & [Clear] - clears the command line.
- [Shift] & [Delay] - posts follow.
- [Shift] & Encoder Paging Key - posts the category to the command line. For beam subcategories, press Image, Form or Shutter twice to post Beam. (Ion/Gio)
- [Shift] & Encoder Movement - accesses fine mode.
- [Shift] & Encoder Push/ Toggle - posts the parameter to the command line. (Ion)
- [Shift] & Gel Tile - cycles through three modes of Brightness.
- [Shift] & [Full] or [Shift] & [Out] - flash on or flash out.
- [Shift] & [+] or [Shift] & [-] - +% or -%.
- [Shift] & [Highlight] - appends highlight to the current channel selection.
- [Shift] & [Select Last] - posts additional channel selection options to the softkeys.
- [Shift] & [Sneak] - makes manual data unmanual.
- [Shift] & [Update] - shortcut to Save.
- [Shift] & restore manual faders - reset faders to zero without asserting control.
- [Shift] & {Direct Select} - posts DS to the command line without terminating.
- [Shift] & [Next] or [Shift] & [Last] - advances the cue without changing channel selection.
- [Sneak] [Sneak] - releases NPs of selected channels and self terminates.
- [Timing Disable] & [Go] or & [Back] - cuts the next cue or cuts the last cue.
- [Thru] [Thru] - [Thru] command accesses only channels displayed in the current flexi-state (unless the range specified is NOT in the current display). [Thru] [Thru] selects the range regardless of the flexi mode.
- [Trace] [Trace] - forces a previously inactive light to track its new intensity setting backwards.
- [Undo] - clears an unterminated command line. Otherwise opens undo controls.
- [Update] & [Sub Bump] - to update a specific submaster.
- [n] [At] [/] [/] [m] [Enter] - sets direct DMX value (m) for channel (n).
- [Shift] & [Delay] [Delay] - posts hang to the command line.
- [Shift] & [About] - opens a command line search window.
- [Shift] & [.] - posts minus cells to the command line. This is for use with multicell fixtures.
- [.] - posts cells or cells only to the command line when used after channel number(s). This is for use with multicell fixtures.
- [Shift] & [Int Palette] - posts preset on the command line (Element & Element 2).
- [Displays] & [Record] - puts a marker in the log file.
