35.7 HedgeHog 4
35.7.1 Input and Output Connections
Mains in: IEC 320 connector (5A/250V rated cable supplied) 100-240V, 50/60Hz, 2.5 A maximum
USB: 2 x Universal Serial Bus 2.0 ports (rear)
Ethernet: 1 x Gigabit base-TX Ethernet port
DMX out: 2 x Neutrik 5 pin female XLR
Keyboard: Not included (Generic Class USB keyboards Supported)
35.7.2 Power, Weight and Dimensions
Power: 250W
Weight: 17 lbs (7.7 kg)
Dimensions: 20.74” (526.8mm) wide
21.83” (554.37mm) deep
3.97" (100.78mm) high
