35.10 Nano Hog 4
Prev
Section 35: Technical Specifications
Next
35.10 Nano Hog 4
35.10.1 Input and Output Connections
Mains in:
External DC Power Supply (5.5A/12V)
100-240V, 50/60Hz, 1.5A maximum
USB:
Type B USB Input Socket
Universal Serial Bus 2.0 ports (2 rear)
DMX Out:
4 x 5-pin XLR DMX Outputs (when DMX output kit is installed)
35.10.2 Power, Weight and Dimensions
Power:
5W
Weight:
18.1 lbs (8.21 kg)
Dimensions:
26.7” (678.18mm) wide
13.76” (349.52mm) deep
3.54” (89.85mm) high
