![]() | Tip |
Copying or moving cues affect hard values only; the cue you wish to copy/move may also contain tracked values that create the current onstage state. If you wish to copy this look rather than just changes made by the current cue, use Copy and Move with State; see Using State. |
To make a copy of a cue in the same cuelist:
Make sure that the cuelist you want to work with is on the currently chosen master.
Cue 1
Copy Cue 2
Enter : copies the contents of Cue 1 to Cue 2.
To copy in a cuelist other than the chosen one, or to copy between cuelists, specify the cuelist with the List key. For example:
List 1
Cue 1
Copy List 2
Cue 2
Enter : copies the contents of Cue 1 of Cuelist 1 to Cue 2 of Cuelist 2.
To copy a range of cues:
List 1
Cue 1
Thru 4
Copy List 2
Cue 2
Enter : copies the contents of cues 1 to 4 of Cuelist 1 to Cuelist 2, starting at Cue 2.
If the destination cue(s) already exist, you will be asked to choose an option: Insert, Merge and Replace.
To move a cue to a new location:
Cue 1
Move Cue 2
Enter : moves the cue from 1 to Cue 2, effectively removing Cue 1.
