Command keys are created by using the "move" syntax of the console to assign existing show objects to empty cells in the commands directory or to blank function keys on the front panel (when the console's function keys are set to CMD mode). Please note that the original show objects are not actually being moved.
Here is an example of how to create a command key for cuelist 1:
List 1
Move
Press any empty cell in the command directory or press any empty function key on the front panel (if the console's function keys are set to command mode)
![]() | Tip |
When command keys are created they automatically inherit the name and color-coding of the show object that they are linked to. Changing the name or color-coding of a command key will change the name and color-coding of the show object it is linked to and vice-versa. |
