Hog 4 OS supports routing Art-Net Input from external sources on the Fixture Net network to DMX Processor Outputs. Hog 4 OS does not support DMX In for console control or signal routing.
To set a dmx channel or group of dmx channels to values based on a remote Art-Net source:
Open the DMX Output window (press the SETUP key on the front panel and select the DMX button on the main toolbar)
Use the down menus at the top of the DMX Output window to select a processor and universe.
Select the desired dmx channel cell in the spreadsheet (or highlight a group of dmx channel cells)
Press the "Set to Art-Net Input" button in the top (the value will now be displayed in red)
Open the network window
Select the corresponding processor and press the
button.Select the
tab of the Processor Settings Window.Press the
button.Use the scroll boxes to select a range of universe for which you want to configure ArtNet Input. Press
.It is important to note that a universe can only have one ArtNet Input mapping per processor.
Modify the port value (incoming ArtNet Sub/Uni) for each mapping as needed.
Press
or .The processor will now route the incoming Art-Net stream to the universe and output to the channels set to Art-Net input in the dmx window.
![]() | Caution |
Do not configure a processor's Art-Net input and output settings for a given universe to the same Art-Net subnet/universe. |
