In most cases the best way to ensure you have the latest Hog 4 OS fixture library on your console is to ensure you are running the latest version of Hog 4 OS. However, sometimes High End will release full library updates as well as smaller single fixture libraries on the High End System website between software releases in order to ensure users have the most up-to-date information as possible. This section will cover how to install these full libraries onto a Hog 4 series console.
To install a fixture library onto console:
Download a supported fixture library from the web.
The latest full fixture library can be found at www.highend.com
Copy the downloaded fixture library to a USB flash drive.
Insert USB flash drive into the console.
Navigate to the Hog 4 OS start screen and click on the File Browser button.
Use the file browser window to drag and drop the fixture library file from the USB flash drive into the libraries directory on the console.
The fixture library is now installed on the console.
To schedule fixtures from the different fixture libraries installed on the console:
Open the Fixture Window.
Click on the Add Fixtures button.
Click on the Select Library button at the bottom of the fixture schedule window.
Choose the installed fixture library you want to schedule fixtures from and press okay.
Use the fixture schedule window to schedule fixtures from the fixture library you selected in step 4.
