To launch a new show:
Press the Launch New Show button in the start window.
Use the browser window to select the directory where you wish to store the show, give it a name, and then press the finish button.
Congratulations! You are now running a new show file.
![]() | TIP |
If the launch new show button is greyed out or unavailable make sure that the "run server" option is checked in the start screen's settings window. If "run server" is checked but the new show button is still greyed out then it's possible another console is running a show on the same port on the network. |
