Only connect this equipment to a branch circuit having a maximum overload protection of 20 A.
If this equipment was received without a line cord plug, attach the appropriate line cord plug according to the following code:
brown - live
blue - neutral
green/yellow - earth
As the colours of the cores in the mains lead of this equipment may not correspond with the coloured markings identifying the terminals in your plug, proceed as follows:
the core which is coloured green and yellow must be connected to the terminal in the plug which is marked with the letter E or by the earth symbol
, or coloured green or green and yellow.
the core which is coloured blue must be connected to the terminal which is marked with the letter N or coloured black.
the core which is coloured brown must be connected to the terminal which is marked with the letter L or coloured red.
Class I equipment. This equipment must be earthed.
Equipment suitable for dry locations only. Do not expose this equipment to rain or moisture.
Disconnect power before servicing.
Refer servicing to qualified personnel; no user serviceable parts inside.
