Scene timing controls the fade-in and delay of a scene when it is run on a master.
You assign and edit scene timings in the same way as for cues; see Fade, Delay, and Path. You can assign scene timing in the Programmer before recording the scene, or later in the scene editor. You can also assign the fade time of a scene from the command line. For example, to give Scene 1 a fade time of 6 seconds:
Scene
1
Time
6
Enter
You can also record fade times with a mask. For example:
Scene
1
Fixture
1 + 2
Colour
Time
4
Enter : sets the fade time for the colour parameter
values of fixtures 1 and 2 in Scene 1.
