Central Control Server Properties
Selecting the Central Control Server from the Browser displays its properties in the Property Editor.
A Paradigm Central Control Server (P-CCS) defaults IP settings of "Manual" with IP address 10.101.10.10, Subnet Mask 255.255.0.0 for the primary lighting interface.
TIP: If "Automatic" is the selected address method, this means that Link Local IP settings are used when no DHCP service is found on that interface.
This property defaults to 0.0.0.0, which means the Net3 Conductor Network Services Gateway is the NTP master. Configuring another IP address for this property instructs the P-CCS to use a different external time server.
All Paradigm products, by default, participate in Net3 logging (mainly for errors).
