To create a new show file, navigate within the browser to File > New and press [Select].
You will be prompted for confirmation that you want to create a new show. Any unsaved show data will be lost. Press {OK} to confirm or {Cancel} to discontinue the operation.
If you want your Augment3d model to be included in the new show, check the box labeled "Preserve Augment3d Model." For more information, see Augment3d (on page 1).
Ion Classic users can select a 1-to-1 patch by pressing the {Patch 1to1} option. A new show created with {Patch 1to1} selected will have a 1-to-1 patch and 1-to-1 channel to sub assignment. On Element Classic, this option is enabled by default.
A template show file can be assigned in the ECU via Settings > General.
When a show file is assigned as a template, Eos will create a copy of the file in the Templates folder to be used as the default starting point for any new show files. A new option will appear in the CIA under File > New From Template (Template Show File Name) to create a new show file identical to the template. A blank show file can always be created with the File > New option.
Templates can be managed via the File Manager, and are unaffected by deep clears. See Settings > Maintenance.
