Interface Protocols
Note:  Some settings can also be accessed from within the Eos application via Setup > Device >Network.
MultiConsole
Enables multi-console communication on the selected port. Enabled by default. See Multi-Console Setup.
Network Type
This setting adjusts the timeout period before a backup device will take control from the primary.
File Transfer
This setting adjusts the show file transfer speed between devices. The default setting is Fast File Transfer.
Note:  If you are experiencing connection issues between devices, you can change the setting to Normal File Transfer for a slower transfer speed.
Sensor/FDX3000 Feedback
Allows your console to receive feedback over the network from CEM+, CEM3, or FDX3000. Enabled by default. See [About] Address.
Network RDM
Enables RDM functionality on all Ethernet ports, including device discovery. Enabled by default.
Note:  RDM requires use of a Net3 or Response Gateway. Net3 Gateways must be using version 5.1 or higher.
