This section describes the processes involved in changing your system, user, and device settings to meet your preferences.
For more information on settings not found in Setup, see About the Eos Configuration Utility.
To enter the setup screen, select [Displays], then {Setup}, or navigate to Setup via the browser. users can also use the dedicated hardkey.
The CIA will repaint to display the following setup sections and their subsections:
Selecting a subsection will display any associated settings fields. To change the setting for any of these fields, press the field in the CIA to activate it. If the field requires data, enter it from the keypad. If the field is a toggle state, one press of the button will switch the field to its other state.
