Parameter, All
Shows all the available parameters.
Note: The Param button is only present if you have patched fixtures with those capabilities.
Controls the parameters of the selected fixture(s). Only fixtures with parameters may be controlled here.
Pick a parameter and swipe the value box up and down to change values. A green arrow will appear on the value box when you are swiping it.
Pick the value box with one press to open a filmstrip view of the available settings.
The filmstrip may be scrolled left or right to see all the choices.
