To select a control you must first exit draw mode. To exit draw mode, click on the [Select Mode] button in the toolbar or press (Esc) on your alphanumeric keyboard. Next select a control on the Page workspace or click on the control's name in Object Browser.
While in Select Mode, you can select multiple controls:
A parent object can be defined as any frame, tab, pop up, and even the page itself. Parent objects have a selection context which allows you to add and select controls that fall within the parent object boundaries. You may select any and all controls within the boundary of a parent object but you cannot select multiple controls of two different parent objects at one time.
Select all controls within a selected parent object at once using the following method:
A boundary rectangle is automatically drawn around the selection and includes handles to resize the selected objects.
To delete a control:
To move a control or multiple controls, you must first select them.
You can use the (Shift) key as a toggle to constrain the movement of one or more controls so that they move only in a horizontal or vertical direction.
Click to select a control or multiple controls as required then press and hold the (Shift) key on your alphanumeric keyboard. Keeping the mouse button held and moving the control(s) maintains the horizontal or vertical axis for the selection. Releasing the (Shift) key will unlock the locked axis.
When controls of the same size, type, and even state are required on different pages of your configuration; you can copy and paste a control between pages.
Click to select the [Show Grid] icon on the configuration toolbar to enable snap to grid functionality. Once enabled, the grid is displayed behind all controls in the Page workspace.
Grid spacing can be changed using the grid spacing box located to the right of the [Show Grid] button .
To resize a control or multiple controls of varying sizes at once, changing their proportion to equal sizes, you must first select the controls to be modified. See "Selecting Controls" for detailed instruction. Controls cannot be resized larger than their parent object boundary. Once the controls are selected, use the tools in the configuration toolbar to resize and align
the controls.
From left to right, the tools are:
The layout spacing tool is located in the toolbar with the layout proportion (size) tools
. The layout spacing tool allows you to increase or decrease the spacing between the controls, in pixel increments. This tool works in conjunction with the layout proportion tools such as the [Layout Horizontal], [Layout Vertical], and [Layout Grid].
You can resize controls that have been laid out using the layout tools to fit within a bounding box. For example if you have four buttons selected and utilize the [Layout Vertical] tool, the buttons cluster together in a bounding box separated by the amount of pixels that are set in the layout spacing tool.
With the cluster of controls still selected, you can change the spacing between the buttons as needed, increasing the space between the buttons (raising the numeric value in the layout spacing tool) or decreasing the space between the controls (lowering the numeric value in the layout spacing tool). The bounding box remains the same size and in the same location, no matter what spacing is specified for between the controls.
To lock the position of all controls in the configuration, click the [Lock Position] button in the toolbar. To unlock this control, click the [Lock Position] button again.
