Several of the functions of the Hog 4 OS can be accessed through use of the front panel key combinations and onscreen button combinations found in the tables below.
Programming & Patching | |
Pig + Blind | Fades Changes when blinding and un-blinding |
Pig + Clear | Undo |
Pig + Flip | Sends fixture selection through possible flip positions in reverse order |
Pig + Park | Un-parks selected fixtures, rather than parking them |
Pig + Touch | Touches specified parameters and fixtures but as record ineligible |
Pig + parameter wheels | Allows fine adjustment of the wheel's value |
Pig + Record | inverts the current kind masking scheme for that record operation |
Pig + Merge | inverts the current kind masking scheme for that merge operation |
Pig + Fixture | Tokens the word "plot" on the command line |
+ + encoder wheel | Sets wheel to maximum value when encoder turned clockwiseSets wheel to minimum value when encoder turned counter-clockwise |
- + encoder wheel | Inverts wheel between positive and negative values when available (ex: gobo rotation) |
bksp + encoder wheel | knocks out the coordinating parameter value for selected fixtures in the current active editor |
. + encoder wheel | Sets wheel to default value |
Pig + . + encoder wheel | Sets wheel to default value and mode |
. + kind button | Sets all parameters of that kind to their default values |
Open + Fixture | Opens the fixture window. |
Pig + @ | When patching with View by DP enabled, un-patches the selected fixtures |
Pig + I-Wheel | Increases/decreases intensities in proportion to their individual level. |
Window Control | |
Pig + Open + Colour | Opens the Colour Picker window |
Pig + Open + Beam | Opens the Media Picker window |
Pig + Open + Fixture | Opens the Plots directory |
Open + backspace | Closes active window |
Open + Thru | Cycles through open windows (change focus) |
Open + Full | Maximizes active window |
Open + @ | Moves active window to next screen |
Open + / | Copies and splits active window |
Open + + | Sizes active window clockwise |
Open + - | Sizes active window counter-clockwise |
Pig + Size (on Window Control Toolbar) | Cycles through the possible window sizes in the reverse order |
Open + 1-9 | Opens view 1-9 |
Open + 0 | Opens view 10 |
Pig + Next (on the View Toolbar) | Changes view toolbar to previous page of views, rather than next page of views |
Open + first encoder wheel | Vertical Window Scroll (up/down) |
Open + second encoder wheel | Horizontal Window Scroll (left/right) |
Open + third encoder wheel | Zoom (plot window only) |
Speadsheets | |
Pig + Set | Acts as a right mouse click |
Pig + arrow keys | Allows for selection of multiple cell items in spreadsheets |
Pig + Backspace | Removes values from the currently highlighted cells in the Programmer or editor |
Pig + Copy | Copies the contents of the currently selected cells |
Pig + Move | Pastes into the currently selected cells |
Directories | |
Pig + arrow keys | Extends directory item selection |
Pig + button in a directory | Overrides directory Guard button |
File Browser | |
Pig + click on file | Allows for selection of multiple files (Pig key is acting like control key) |
Playback | |
Pig + Release | Releases all active cuelists and scenes |
List + Release | Releases any active cuelists NOT attached to masters on the current page |
Scene + Release | Releases any active scenes NOT attached to masters on the current page |
Pig + Main Play | Plays all cuelists and scenes attached to masters on the current page |
Pig + Main Pause | Pauses all cuelists and scenes attached to masters on the current page |
Holding choose | Displays the master's playback rate, effect rate, effect size, and intensity on main encoder wheels |
Console / Debug | |
Pig + Open + Backspace | Opens the Launched Processes window |
Pig + Open + 1 | Opens the Log Viewer window |
Pig + Open + 5 | Opens the debug toolbar |
Pig + Open + Delete | Restarts the console if held for 5 seconds. *On Hog 4-18 holding this key combination for 5 seconds shuts down the console, then the keys must be released and held again for 5 seconds to boot the console. |
Misc | |
Pig + Enter | Toggles the function keys between Kind Key and Command Key mode |
Pig + Setup | Toggles the worklight on and off |
Pig + Undo | Redo |
Pig + text with on-screen keyboard | Acts as a shift key, to type upper case characters |
Setup + first encoder wheel button | Calibrate touchscreens; quit calibration by pressing enter key |
Setup + encoder wheel | Adjusts brightness of LCD backlights, front panel LEDs, desklights, and worklight |
Pig + . | Toggles slot toolbar and encoder wheel toolbar on/off |
Pig + 0, 1, 2, 3, etc. | Toggles playback bars on/off |
