31.1 QWERTY Keyboard Shortcuts
Many functions of Hog 4 OS's can be executed using a standard QWERTY keyboard. To enable keyboard shorcuts press the Pause/Break key or Control + Q on the keyboard until MAP is shown as the keyboard mode on the Command Line Toolbar; see Figure 31.1, “Keyboard Status in the Command Line Toolbar”. Hog 4 OS disables the keyboard shortcuts (MAP mode) when text entry is expected ( for example, after pressing Set or double clicking in a cell). When a text entry session is completed, MAP mode is automatically re-enabled if it was previously enabled.
When keyboard shortcuts are disabled, only the shortcut mapped to the Set key remains functional to allow quick labeling from the external keyboard.
Figure 31.1. Keyboard Status in the Command Line Toolbar
The following table contains a list of Hog 4 OS functions and their respective US keyboard mappings:
Function Keystroke   Function Keystroke
Toggle ShortcutsCTRL Q Main Go] or Space
PigCTRL or F14Main Pause[
OpenESC or OMain BackL
SetINSERT or iSkip FwdK
IntensityF11Skip BackJ
PositionF2GotoG
ColourF3ReleaseZ
BeamF4Pig + ReleaseALT Z or F14 + Z
EffectsF7AssertA
MacroF5Tap Tempo (effects)ALT + [
GroupF1Tap Sync (chases)ALT + ]
FixtureF12Next Page: or ;
SceneF9@' or @
CueF10Full~ or #
ListF8Thru*, > or X
PageF6Minus (-)- or _
RecordRPlus (+)= or +
MergeEslash (/)/ or ?
MoveMPoint (.). or >
CopyPChoose Master 1-10ALT 1 - 0
DeleteD or DeleteGO Master 1-10TAB 1 - 0
UpdateUPause Master 1-10Backspace 1-0
LiveVUndoCTRL Z
TimeTRedoCTRL Y
SetupS Visual CutCTRL X
FanFVisual CopyCTRL C
HighlightHVisual PasteCTRL V
BlindBVisual Select RangeCTRL Cursors
ClearCBackspaceBackspace
NextNEnterEnter
BackYGM\
AllALT NCenter ChooseALT -
  Bottom Right toolbarTAB F1-12
  Top Right toolbarALT F1-12
