To send OSC messages from the Console:
Connect your OSC controller to a physical network port that is attached to the same local area network as the console's HogNet port.
Setup → Network : opens the network window
Right click on the console number and select Settings : opens the Settings window
In the Open Sound Control pane, enable OSC Out and assign the output port to match the input port of your OSC output device. You must specify the IP address you wish to output to as well as which protocol you wish to use for OSC output.
