Hog 4 OS uses the following OSC paths for sending and receiving playback messages:
Hog 4 OS | OSC Command Path | Data |
Go a Cuelist | / hog / playback / go / 0 | cuelist # |
Go a specific cue in a list (goto) | / hog / playback / go / 0 | cuelist #.cue # |
Halt a Cuelist | / hog / playback / halt / 0 | cuelist # |
Resume a halted cuelist | / hog / playback / resume / 0 | cuelist # |
Release a Cuelist | / hog / playback / release / 0 | cuelist # |
Go a Scene | / hog / playback / go / 1 | scene # |
Halt a Scene | / hog / playback / halt / 1 | scene # |
Release a Scene | / hog / playback / release / 1 | scene # |
Go a Macro | / hog / playback / go / 2 | macro # |
Halt a Macro | / hog / playback / halt / 2 | macro # |
Release a Marco | / hog / playback / release / 2 | macro # |
Hog 4 OS uses the following OSC paths for receiving Midi Note input:
For example, Hog 4 OS recognizes / hog / midi / on / 1 / 10 as "note on" for note 10 on channel 1.
Midi Note On | / hog / midi / on / channel # / note # | velocity |
Midi Note Off | / hog / midi / off / channel # / note # | velocity |
Note: if velocity = 0, then message is treated as note off
Hog 4 OS uses the following OSC paths for receiving front panel key commands:
Key | OSC Command Path |
Choose | / hog / hardware / choose / master # |
Go | / hog / hardware / go / master # |
Pause | / hog / hardware / pause / master # |
Back | / hog / hardware / goback / master # |
Flash | / hog / hardware / flash / master # |
Encoder Wheel Button | / hog / hardware / ewheelbutton / # |
i-Wheel Up Button | / hog / hardware / iwheelup |
iWheel Down Button | / hog / hardware / iwheeldown |
Pig | / hog / hardware / pig |
Period | / hog / hardware / period |
Arrow Up | / hog / hardware / up |
Arrow Down | / hog / hardware / down |
Arrow Left | / hog / hardware / left |
Arrow Right | / hog / hardware / right |
@ key | / hog / hardware / at |
- | / hog / hardware / minus |
+ | / hog / hardware / plus |
/ | / hog / hardware / slash |
Backspace | / hog / hardware / backspace |
Function keys | / hog / hardware / h# |
Main Play | / hog / hardware / maingo |
Main Pause | / hog / hardware / mainhalt |
Main Back | / hog / hardware / mainback |
Center Choose | / hog / hardware / mainchoose |
Skip Forward | / hog / hardware / skipfwd |
Skip Back | / hog / hardware / skipback |
A data value of 1 = Key Press On
A data value of 0 = Key Press Off
0 | / hog / hardware / zero |
1 | / hog / hardware / one |
2 | / hog / hardware / two |
3 | / hog / hardware / three |
4 | / hog / hardware / four |
5 | / hog / hardware / five |
6 | / hog / hardware / six |
7 | / hog / hardware / seven |
8 | / hog / hardware / eight |
9 | / hog / hardware / nine |
Hog 4 OS uses the OSC paths listed in the table below for receiving fader and encoder commands.
Front Panel Fader/Encoder | Incoming OSC Command Path | Data |
Trackball POS Mode | / hog / hardware / posmode | 0= toggle off1 = toggle on |
Trackball Position | / hog / hardware / trackball | X,Y values |
Grand Master Fader | / hog / hardware / fader / 0 | 0 < 255 fader value |
Main Encoder Wheels | / hog / hardware / encoderwheel / # | -20 < 20 variable value |
Rate Wheel | / hog / hardware / ratewheel | -20 < 20 variable value |
i-Wheel | / hog / hardware / iwheel | -20 < 20 variable value |
Hog 4 OS outputs the following status messages to OSC controllers:
Hog 4 OS | OSC Command Path | Example |
Front Panel LED Status | / hog / status / led / button name | hog / status / led / clear |
The Command Line | / hog / status / commandline | hog / status / commandline |
Encoder Wheel Labels | / hog / status / encoderwheel# / label | hog / status / encoderwheel3 / label |
Encoder Wheel Values | / hog / status / encoderwheel# / value | hog / status / encoderwheel3 / value |
Function Key Labels (Line 1) | / hog / status / h# / line1 | / hog / status / h1 / line1 |
Function Key Labels (Line 2) | / hog / status / h# / line2 | / hog / status / h1 / line2 |
Most Recent Chat Message | / hog / status / chatline1 | / hog / status / chatline1 |
Second Most Recent Chat Message | / hog / status / chatline2 | / hog / status / chatline2 |
Third Most Recent Chat Message | / hog / status / chatline3 | / hog / status / chatline3 |
