Cuelists can be copied and moved within the Cuelist Directory. To open the Cuelist Directory:
Open + List
To make a copy of a cuelist:
List
1
Copy
List
2
Enter : copies Cuelist 1 to Cuelist 2.
If the destination cuelist already exists, you will be asked to choose an option: Insert, Merge and Replace.
To move a cuelist to a new location within the Cuelist Directory:
List
1
Move
List
2
Enter : moves Cuelist 1 to Cuelist 2.
When copying or moving a cuelist, if the destination location already has a cuelist in it, you will be prompted with record options of Insert, Merge or Replace:
Insert: creates a new destination cuelist. The new cuelist will be assigned a free location just before the one chosen, using a point number if necessary.
Merge: Incorporates the source information into the destination cuelist. If the cue numbers are in both cuelists, the new parameter values of the cues will replace the old.
Replace: Overwrites the cuelist information in that destination.
If you are copying a cuelist, all three options are available. If you are moving a cuelist, only the Insert option is available.
![]() | Tip |
If you know that you are about to copy or move a cuelist to an existing destination, you can pre-select Insert, Merge or Replace from the Record Options Toolbar. This appears after you press the Record, Copy or Move keys. |
